Thank, but i want C++ :v
Do you have tutorial about develop windows app using c++?
I donāt know anything about windows but I remember back in the day, visual studio had some pushbutton āwizardsā for making c++ apps. You should learn the language itself first. If you want an intro book, Iād go with Stroustrupās: Stroustrup: Programming -- Principles and Practice Using C++ (Second Edition)
If C++ is your first programming language and you are not a masochist, you are probably making a mistake.
I learned the basic and i want to create something
What is stopping you then? Are you looking for projects to work on, exercises, or what?
I want to create a simple application and continue practice
If you want to write a windows desktop app with a gui toolkit, you could look for an online tutorial. This is sort of te wrong forum for advice with that kind of thing since itās a hosting forum, so the programmers here are mostly server-side programmers (Iām one) and they mostly use Linux rather than Windows. And really, almost nobody writes Windows apps any more. Itās either web apps or mobile apps. And even mobile apps have declined as more stuff is on the web. So the stuff youāre asking about is basically a 1990ās thing. But, you could look at WxWidgets or qt.io for some C++ gui toolkits. I havenāt used either myself.
GUI programming is not exactly rocket science but it is very very tedious to get all the little bits right. You might find it easier to start off with something text based, or server based.
Yeahh, iām thinking about your advice.
Pythonās good but shoud i stop learning c++?
I think itās reasonable for you to put C++ aside for a while. You can always take it up again wherever you want. It will just make more sense to you when you have more programming experience. I have not read Stroustrupās intro book though. I have his other book which is more advanced (not for beginners), but I like his writing enough to expect his intro book to also be good.
C++ is full of things that make you ask āwell why did they do thatā. Stroustrup is the guy who invented C++, so he is able to explain exactly why he did each thing as he did, while other authors can only guess.
Then do you know Python or any good Python learning resource .
Iāve just google and found one call Learn Python the hardway
Iād take a break from C++ and focus on something else for a little. Something its easier once youāve given yourself a break from the materials. Thereās plenty of MOOC classes that can help you out, and dont undersestimate the power behind youtube tutorials
Iāll take it. Thank you
