WHMCS + Blesta License Verification Discord Bot
Howdy y’all! Just thought I’d share a little project I’ve been working on. I actually created this bot several months ago, but just got around to refactoring and posting up the code today. Shoutout to @JackHadrill and @doghouch for helping me test the bot out a bunch over the past couple months.
GitHub repo: https://github.com/masonr/Discord-Billing-License-Bot
Purpose:
Simple Discord bot that will verify WHMCS and Blesta billing panel licenses. Call the bot’s command and pass a domain as an argument and it will attempt to verify the license.
How to Get Bot:
Two options - hosted or self-hosted.
  • Hosted: I’m hosting the bot on one of my servers, so you can invite the bot to your Discord server using this link: https://discordapp.com/oauth2/authorize?&client_id=480073510790889472&scope=bot&permissions=0. The bot does not need any permissions.
  • Self-Hosted: Alternatively, you can host the bot yourself using the instructions on the GitHub page. All the code and instructions are available on the GitHub project page. The bot requires Python 3 and two modules (Discord client + Beautiful Soup) to run.
Usage:
!command [domain]
!command help
Supported Commands:
!license - checks WHMCS and Blesta license validity
!licence - (same as above)
!whmcs - checks WHMCS license validity
!blesta - checks Blesta license validity
Example Commands:
!license google.com
!whmcs unknown.host
!blesta billing.hostingcompany.net
!license help
Screenshots:
!license command with valid license -
!license command with invalid license -
!whmcs command with valid license -
!blesta command with valid license -
!license command with error -
!license help command -
Questions/Feedback:
I’m open to any questions or feedback that you may have. Any features you think that would be beneficial, feel free to suggest them or fork the repo + PR your changes. Feel free to email or PM me if you encounter any errors or have any issues getting the bot sorted.
Cheers!
-Mason
#2
Ah yes, I remember seeing this. Great work! :smiley:
#3
Just curious, how do you verify Blesta licenses? I don’t believe they have a public verification portal (as with WHMCS)?
#4
They do, it’s here: https://account.blesta.com/client/plugin/license_verify/
It’s very similar to WHMCS’s verification page, but requires a csrftoken and a cookie to properly submit a query to the page. You’ll see the extra jazz in the code to make that happen.
#5
I was not aware of that page, thanks.
#6
So glad you didn’t do ho-ost. You’d find out my dark nulled secrets.
Nice project.
#7
You’re in the clear… for now :wink:
And thank you, kind sir!
#8
Got the Bot approved on the Discord Bot site :smiley:
#9
Nice! Thanks to your source code, I’ve implemented similar functionality into my tools API :stuck_out_tongue: You can make a GET or POST request containing a domain and then receive true or false whether the domain is authorized or not. I also added support for CPanel.
Got to say, the Blesta integration was pretty annoying to do! Would’ve taken a lot longer if I didn’t have your code as a reference.
#10
Sweet! :smiley: glad the code was useful!
Not sure why Blesta’s verification page is set up the way it is and it took a ton of trial and error with curl commands till I finally figured out what’s needed with the POST message, but eventually figured it out :stuck_out_tongue:
Also, now that you mention it I may add cPanel verification to the bot.
