What is that and why would it be using too much CPU?
It was fine a couple of hours ago. This is a MySQL server.
My first thought is compromised server and that isn’t doing what it wants you to think it’s doing.
Oh shit. Seeing the TIME columns, it’s weird.
strace -s 1024 -f -p 5057
to see if there’s something anomalous. With @Jarland you got rooted. An strace for sure will give you an idea what type of system calls it’s making. Otherwise check dmesg
for a potential kernel panic.
Edit: lsof -p 5057
might give you a better idea what files it has open, where it’s cwd is, and so on as well.
yep, lsof
is the way
and after identifying the filenames, use fuser to get some more info
Thank you both. Yes, learned about lsof here at HostBalls
Output:
[root@dal03 ~]# lsof -p 5057
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
rmmod 5057 root cwd DIR 253,2 4096 2 /
rmmod 5057 root rtd DIR 253,2 4096 2 /
rmmod 5057 root txt REG 253,2 146680 11217 /usr/bin/kmod
rmmod 5057 root mem REG 253,2 142144 4153 /usr/lib64/libpthread-2.17.so
rmmod 5057 root mem REG 253,2 2156240 4125 /usr/lib64/libc-2.17.so
rmmod 5057 root mem REG 253,2 88776 17016 /usr/lib64/libgcc_s-4.8.5-20150702.so.1
rmmod 5057 root mem REG 253,2 90248 4451 /usr/lib64/libz.so.1.2.7
rmmod 5057 root mem REG 253,2 157424 5297 /usr/lib64/liblzma.so.5.2.2
rmmod 5057 root mem REG 253,2 163312 2307 /usr/lib64/ld-2.17.so
rmmod 5057 root 0r FIFO 0,9 0t0 315805920 pipe
rmmod 5057 root 1w FIFO 0,9 0t0 315805921 pipe
rmmod 5057 root 2w FIFO 0,9 0t0 315805921 pipe
/usr/bin/kmod
is an old file according to ls
I found this binary at /root/
created today.
-rw------- 1 root root 1024 Jun 6 10:26 .rnd
HOOOWWWW?
WHYYYYYYYY?
I see the .rnd was generated by OpenSSL. I run openssl dhparam
today.
I didn’t see anything interesting with fuser
Rebooted the server and now it’s idling.
Fuck.
I’m going to rebuild it anyway and put more restrictions. If it got hacked, I don’t have any idea how it happened, it was running mariadb service only.
@imok didn’t you write something about trying to install firewalld on ovz or lxc or the likes? is that the same system?
rmmod should do exactly what the name suggests, removing kernel modules. in this case nf_conntrack …
in context with you maybe fiddling around with different firewall software that might make sense and it probably just got stuck along the way?
so while I agree it’s always good to be cautious this doesn’t look that worrysome to me
I was about to reply … but @Falzo beat me to it …
No, it’s another machine. This is KVM.
But yes, I was playing with firewalld around the hour problems started.
I think something just got stuck. I reinstalled the server anyway.
