microLXC Public Test
Hey,
If you are bored and wanna play around with a LXC container: https://microlxc.net/
Currently AU and JP are available, you can pick between 128 and 256MB packages.
As usual some requirements apply:
  • Your account needs to be 3 months old
  • You need to have at least 50 Posts
  • You need to have at least 50 Likes
If you meet these, you can go on the website, and to verify that you are you, you need to post the token that will be given to you in this thread. The Bot will do the rest.
If stuff goes well, it will be publicly available at end of the next week.
Please report bugs and suggestions.
PS: IPv6 is DHCP based in AU but JP needs Static config, which is automatically configured on Debian & Devuan but not on CentOS/Ubuntu needs to be done by hand yet. You can find your IPv6 in the Panel just substract -1 for the Gateway.
Will be used to reboot my shitty online.net 3€ dedi that regularly crashes lol
676b-61d5-876c-907d
Edits
1: Just before the “deploying VPS” (IIRC) step the status bar went back to stage 1
2: Calculating upgrade... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Noice
3: Holy shit, cron takes 76.8MB After this operation, 76.8 MB of additional disk space will be used.
4: What the fuck is that garbage not the greatest font?
This is extremely confusing. I got no code. Oh well… good luck to whom got one.
@root You got a code, the hole process can take a few minutes.
Maybe there is a bug that I didn’t show it? or did you closed the tab to fast?
I just received the message: Deploy yay! with a gif image of a chaotic lamb.
Would be nice if the checkbox on the ToS is white. Had a hard time knowing I did actually click the button :stuck_out_tongue:
And I was also not able to get the token. All I see is this :frowning:
@root If you got a better gif, lemme know.
@sanvit Small shock, fixed an SQL prepare error on my side, I told SQL to expect a integer but the requestID is a string, so It did select the first request which was from Psycho. Fixed.
@MrPsycho
  1. Fixed
    2/3. Yea these images get rebuild daily + updated every few days automatically on the nodes, pretty neat. Its pretty minimalistic, not even ssh is installed by default or a password is set.
  2. I will look into the font.
Should I re-deploy, or is there a way to retrieve my token?
@sanvit Just go on the Deploy page, it will check if the request is still valid, could be already expired.
d3ef-9230-927a-6b07
The server seems to be down?
And the script seems to send requests even though the prior request is pending (maybe not a big issue though).
5675-2633-6ea4-0b21
It seems there is a trick: when “Verifying” I needed to wait for ~20 seconds.
@sanvit Yea, needs to be fixed, thanks.
Besides, the connection issue, seems like network related, no 500s in the logs.
Also I noticed also decent amount of Steal while the kVM is idle, sucks.
Likely need to migrate.
@root There is no trick, you just have to wait, the page refreshes every 10 seconds.
f53b-adce-f3af-c3bb
@Neoon
Using Debian 10 in JP, and IPv6 is configured by default, but not working. Ping gives error from gateway: “Destination unreachable: Address unreachable”.
@root It seems to work fine now, I did some changes, lemme know if it happens again.
Thank you @Neoon
  • Life is meaningless without meditation about oneself.
  • Morning coffee is meaningless without love reflection in a beautiful person.
  • A VPS is meaningless without a benchmark; so here is bench.sh on Japan location.
CPU model            : Intel Xeon E312xx (Sandy Bridge)
Number of cores      : 2
CPU frequency        : 2199.998 MHz
Total size of Disk   : 2.3 GB (0.8 GB Used)
Total amount of Mem  : 244 MB (16 MB Used)
Total amount of Swap : 2047 MB (18 MB Used)
System uptime        : 0 days, 0 hour 16 min
Load average         : 1.70, 2.75, 1.72
OS                   : Debian GNU/Linux 10
Arch                 : x86_64 (64 Bit)
Kernel               : 5.4.0-37-generic
I/O speed(1st run)   : 101 MB/s
I/O speed(2nd run)   : 154 MB/s
I/O speed(3rd run)   : 139 MB/s
Average I/O speed    : 131.3 MB/s
Node Name                       IPv4 address            Download Speed
CacheFly                        204.93.150.152          2.90MB/s
Linode, Tokyo2, JP              139.162.65.37           2.91MB/s
Linode, Singapore, SG           139.162.23.4            2.89MB/s
Linode, London, UK              176.58.107.39           2.27MB/s
Linode, Frankfurt, DE           139.162.130.8           2.20MB/s
Linode, Fremont, CA             50.116.14.9             2.87MB/s
Softlayer, Dallas, TX           173.192.68.18           2.51MB/s
Softlayer, Seattle, WA          67.228.112.250          2.76MB/s
Softlayer, Frankfurt, DE        159.122.69.4            2.52MB/s
Softlayer, Singapore, SG        119.81.28.170           2.76MB/s
Softlayer, HongKong, CN         119.81.130.170          2.66MB/s
@Mason - YABS is a success, but there is no light version. That script does not work on such small NAT servers, because of space issues.
65c4-f969-54c0-b401
Thanks again!
7e56-8140-f196-43d4
I’d like to help test it out but I it always returns “invalid SSH key” :man_shrugging:
EDIT: Nevermind
8a72-2e33-6167-135b
