Hi!
I bought a server and after running YABS I see disk speed is not as fast as another server I have.
I’m using 2x240GB SSD in soft RAID1.
YABS
# Yet-Another-Bench-Script #
# v2020-09-21 #
# https://github.com/masonr/yet-another-bench-script #
Thu 05 Nov 2020 12:29:42 PM EST
Basic System Information:
Processor : Intel(R) Xeon(R) CPU E5-2420 v2 @ 2.20GHz
CPU cores : 12 @ 1522.058 MHz
AES-NI : ✔ Enabled
VM-x/AMD-V : ✔ Enabled
RAM : 62Gi
Swap : 14Gi
Disk : 205G
fio Disk Speed Tests (Mixed R/W 50/50):
Block Size | 4k (IOPS) | 64k (IOPS)
Read | 956.00 KB/s (239) | 15.01 MB/s (234)
Write | 991.00 KB/s (247) | 15.56 MB/s (243)
Total | 1.94 MB/s (486) | 30.57 MB/s (477)
Block Size | 512k (IOPS) | 1m (IOPS)
Read | 58.17 MB/s (113) | 62.31 MB/s (60)
Write | 61.02 MB/s (119) | 66.75 MB/s (65)
Total | 119.19 MB/s (232) | 129.07 MB/s (125)
This is the smartctl output:
sda
smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.19.0-12-amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model: FCCT240M500SSD1
Serial Number: 140409659E78
LU WWN Device Id: 5 00a075 109659e78
Firmware Version: MU05
User Capacity: 240,057,409,536 bytes [240 GB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 6
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Thu Nov 5 12:27:36 2020 EST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x03) Offline data collection activity
is in progress.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 1030) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 18) minutes.
Conveyance self-test routine
recommended polling time: ( 3) minutes.
SCT capabilities: (0x0035) SCT Status supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 100 100 000 Pre-fail Always - 36204
5 Reallocated_Sector_Ct 0x0033 092 092 000 Pre-fail Always - 336
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 24414
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 56
171 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
172 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 0
173 Unknown_Attribute 0x0032 181 181 000 Old_age Always - 12947
174 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 56
180 Unused_Rsvd_Blk_Cnt_Tot 0x0033 000 000 000 Pre-fail Always - 3730
183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 000 Old_age Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 26014
194 Temperature_Celsius 0x0022 077 068 000 Old_age Always - 23 (Min/Max 0/32)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 336
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0
202 Unknown_SSD_Attribute 0x0031 181 181 000 Pre-fail Offline - 431
206 Unknown_SSD_Attribute 0x000e 100 100 000 Old_age Always - 0
210 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 77
246 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 53036564077
247 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 1657950280
248 Unknown_Attribute 0x0032 100 100 --- Old_age Always - 4000476292
SMART Error Log Version: 1
Warning: ATA error count 0 inconsistent with error log pointer 4
ATA Error Count: 0
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 0 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
When the command that caused the error occurred, the device was in an unknown state.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 01 f7 fe b7 40 Error: UNC at LBA = 0x00b7fef7 = 12058359
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 d5 01 f7 fe b7 40 00 21d+16:43:14.080 READ FPDMA QUEUED
60 da 01 f6 fe b7 40 00 21d+16:43:14.080 READ FPDMA QUEUED
60 00 01 f5 fe b7 40 00 21d+16:43:14.080 READ FPDMA QUEUED
60 00 01 f4 fe b7 40 00 21d+16:43:14.080 READ FPDMA QUEUED
60 00 01 f3 fe b7 40 00 21d+16:43:14.080 READ FPDMA QUEUED
Error -1 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
40 51 00 00 fe b7 40 Error: UNC at LBA = 0x00b7fe00 = 12058112
60 00 00 00 fe b7 40 00 21d+16:43:14.080 READ FPDMA QUEUED
2f 00 01 10 00 00 e0 00 21d+16:43:14.080 READ LOG EXT
60 da 00 00 fe b7 40 00 21d+16:43:14.080 READ FPDMA QUEUED
61 00 80 b0 4c f1 40 00 21d+16:43:14.080 WRITE FPDMA QUEUED
e5 00 00 00 00 00 00 00 21d+16:43:14.080 CHECK POWER MODE
Error -2 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
61 d5 01 f6 fe b7 40 00 21d+16:43:14.080 WRITE FPDMA QUEUED
60 da 01 c8 a7 f1 40 00 21d+16:43:14.080 READ FPDMA QUEUED
Error -3 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
40 51 01 f6 fe b7 40 Error: UNC at LBA = 0x00b7fef6 = 12058358
60 d5 01 f2 fe b7 40 00 21d+16:43:14.080 READ FPDMA QUEUED
Error -4 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Vendor (0xff) Completed without error 00% 24408 -
# 2 Vendor (0xff) Completed without error 00% 24394 -
# 3 Vendor (0xff) Completed without error 00% 24391 -
# 4 Vendor (0xff) Completed without error 00% 24370 -
# 5 Vendor (0xff) Completed without error 00% 24364 -
# 6 Vendor (0xff) Completed without error 00% 24361 -
# 7 Vendor (0xff) Completed without error 00% 24360 -
# 8 Vendor (0xff) Completed without error 00% 24358 -
# 9 Vendor (0xff) Completed without error 00% 24357 -
#10 Vendor (0xff) Completed without error 00% 24355 -
#11 Vendor (0xff) Completed without error 00% 24355 -
#12 Vendor (0xff) Completed without error 00% 24353 -
#13 Vendor (0xff) Completed without error 00% 24332 -
#14 Vendor (0xff) Completed without error 00% 24326 -
#15 Vendor (0xff) Completed without error 00% 24309 -
#16 Vendor (0xff) Completed without error 00% 24267 -
#17 Vendor (0xff) Completed without error 00% 24246 -
#18 Vendor (0xff) Completed without error 00% 41 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
sdb
Device Model: EDGE SE847-V SSD
Serial Number: CD1606131001EE041
LU WWN Device Id: 5 888914 1001ee041
Firmware Version: P0330AA
ATA Version is: ACS-2 (minor revision not indicated)
Local Time is: Thu Nov 5 12:27:33 2020 EST
Offline data collection status: (0x00) Offline data collection activity
was never started.
been run.
data collection: ( 0) seconds.
capabilities: (0x71) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
No Offline surface scan supported.
SMART capabilities: (0x0002) Does not save SMART data before
entering power-saving mode.
recommended polling time: ( 1) minutes.
1 Raw_Read_Error_Rate 0x0000 100 100 000 Old_age Offline - 0
5 Reallocated_Sector_Ct 0x0000 100 100 000 Old_age Offline - 0
9 Power_On_Hours 0x0000 100 100 000 Old_age Offline - 1333
12 Power_Cycle_Count 0x0000 100 100 000 Old_age Offline - 46
160 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 0
161 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 30
163 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 331
148 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 263340
149 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 3601
150 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 3401
151 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 3558
164 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 348000
165 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 314
166 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 215
167 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 271
169 Unknown_Attribute 0x0000 100 100 001 Old_age Offline - 86
181 Program_Fail_Cnt_Total 0x0000 100 100 000 Old_age Offline - 0
182 Erase_Fail_Count_Total 0x0000 100 100 000 Old_age Offline - 0
192 Power-Off_Retract_Count 0x0000 100 100 000 Old_age Offline - 21
194 Temperature_Celsius 0x0000 100 100 070 Old_age Offline - 16 (24 23 25 27 0)
199 UDMA_CRC_Error_Count 0x0000 100 100 000 Old_age Offline - 0
232 Available_Reservd_Space 0x0000 100 100 000 Old_age Offline - 100
241 Total_LBAs_Written 0x0000 100 100 000 Old_age Offline - 480232
242 Total_LBAs_Read 0x0000 100 100 000 Old_age Offline - 226662
245 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 2055375
246 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 526680
247 Unknown_Attribute 0x0000 100 100 000 Old_age Offline - 0
No Errors Logged
Warning! SMART Self-Test Log Structure error: invalid SMART checksum.
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
6 0 65535 Read_scanning was never started
I should learn to interpret this stuff.
