Hosteons.com - Gigabit as well as 100Mbps unmetered KVM and OpenVZ VPS now with more CPU Cores
We have updated our KVM VPS Packages and offering more CPU Cores in same old packages, existing customers can also submit ticket and ask to upgrade to the newer packages if not upgraded already.
We have also launched new KVM VPS on Gigabit port along with our regular 100Mbps Unmetered KVM VPS.
Server Location: Los Angeles (2 Locations in LA) and New York
Test IPv4 LA1: 103.114.160.9
Test IPv6 LA1: 2402:d0c0:0:2::2
Test IPv4 LA2: 185.255.131.10
Test IPv6 LA2: 2402:d0c0:2:12a::3c26
Test IPv4 NY: 91.189.187.10
Test IPv6 NY: 2402:d0c0:3:2::9423
Looking Glass LA - https://lg.hosteons.com
Looking Glass NY - http://lg.ny.hosteons.com
Server Status / Uptime: https://status.hosteons.com
Some Free Goodies with our VPS Packages:
  1. Free Direct Admin License, just coupon ā€œDAā€ in the order form to get free Direct Admin License
  2. Free Blesta License, just submit a support ticket we will activate it for free
  3. Free Windows 2019 License with KVM VPS 3 and above packages on annual billing cycles.
Coupon/offer details for all VPS Packages:
ā€œRECURR50ā€ - This coupon gives 50% OFF recurring discount on annual billing cycles on our OpenVZ VPS Only applicable on OVZ 1 - OVZ 7 Packages only. (Annual billing cycle gives you additional 25% discount)
ā€œRECURR20ā€ - This coupon gives recurring 20% OFF on all billing cycles except for 256MB and 512 MB OVZ and 256 MB KVM VPS (Annual billing cycle gives you additional 25% discount)
ā€œDOUBLERAMā€ - This coupon will give you DOUBLE RAM, after placing order using this coupon code just submit a support ticket to DOUBLE your VPS RAM)
ā€œDOUBLEDISKā€ - This coupon will give you DOUBLE SSD Disk Space, after placing order using this coupon code just submit a support ticket to DOUBLE your VPS Disk Space (SSD RAID 10)
ā€œUPGRADEā€ - Use this coupon to get a free VPS Package upgrade e.g. if you ordered VPS 1 with 512 MB you can ask for free upgrade to Package VPS 2 with 1024 MB RAM and 10 G Disk space, same applies to all other packages, you basically get free upgrade to next higher VPS Package, once you use this coupon code and received your VPS Please submit a support ticket to get this upgrade. (This offer does not applies to Custom VPS and 256 MB RAM VPS, it can be used for any other VPS Packages and it’s applicable only for new orders) This is a lifetime coupon/upgrade.
All above mentioned coupons are recurring
Our OpenVZ 7 Packages are as under: (for FUSE and DOCKER please submit a support ticket after placing order we will enable it)
OVZ256 MB ($12/year - No coupon codes are applicable on this package)
vCPU Core: 1
RAM: 256 MB
Disk Space: 5 GB SSD
Bandwidth: Unmetered
OS: Linux
IPv4: 1 (Additional IPV4 available for $1 per IP per month)
IPv6: /64
RDNS: Yes
Control Panel: Yes
LA - Shopping Cart - hostEONS.com
NY - Shopping Cart - hostEONS.com
OVZ512 MB ($18/year - No coupon codes are applicable on this package)
vCPU Core: 1
RAM: 512 MB
Disk Space: 10 GB SSD
OS: Linux
IPv6: /64
RDNS: Yes
Control Panel: Yes
LA - https://my.hosteons.com/cart.php?a=add&pid=45
NY - https://my.hosteons.com/cart.php?a=add&pid=69
OVZ1 ($2.4/mo use coupon ā€œRECURR20ā€ or use coupon ā€œUPGRADEā€ to get upgraded to our next VPS Package or use coupon ā€œRECURR50ā€ to get 50% OFF on annual billing cycle)
vCPU Core: 1
RAM: 1 GB
Disk Space: 30 GB SSD
OS: Linux
IPv6: /64
RDNS: Yes
Control Panel: Yes
LA - https://my.hosteons.com/cart.php?a=add&pid=38
NY - https://my.hosteons.com/cart.php?a=add&pid=70
OVZ2 ($4.8/mo use coupon ā€œRECURR20ā€ or use coupon ā€œUPGRADEā€ to get upgraded to our next VPS Package or use coupon ā€œRECURR50ā€ to get 50% OFF on annual billing cycle)
vCPU Core: 2
RAM: 2 GB
Disk Space: 50 GB SSD
OS: Linux
IPv6: /64
RDNS: Yes
Control Panel: Yes
LA - https://my.hosteons.com/cart.php?a=add&pid=39
NY - https://my.hosteons.com/cart.php?a=add&pid=71
We have many more OpenVZ 7 based VPS packages check them out at https://my.hosteons.com/cart.php?gid=12
Gigabit KVM VPS Packages:
Gigabit VPS 1 ($21/year)
CPU Core: 1
RAM 512 MB
Bandwidth: 500 GB
Port: Gigabit
OS: Linux
IPv6: /64
RDNS: Yes
Control Panel: Yes
ORDER Links:
LA: https://my.hosteons.com/cart.php?a=add&pid=77
Gigabit VPS 2 ($3.2/month Use coupon ā€œRECURR20ā€ or use coupon ā€œUPGRADEā€ to get upgraded to our next VPS Package)
CPU Core: 2
RAM 1 GB
Disk Space: 15 GB SSD
Bandwidth: 1 TB
Port: Gigabit
OS: Linux
IPv6: /64
RDNS: Yes
Control Panel: Yes
ORDER Links:
LA: https://my.hosteons.com/cart.php?a=add&pid=78
Gigabit VPS 3 ($4/month Use coupon ā€œRECURR20ā€ or use coupon ā€œUPGRADEā€ to get upgraded to our next VPS Package)
CPU Core: 2
RAM 1.5 GB
Disk Space: 20 GB SSD
Bandwidth: 2 TB
Port: Gigabit
OS: Linux/Windows
IPv6: /64
RDNS: Yes
Control Panel: Yes
ORDER Links:
LA: https://my.hosteons.com/cart.php?a=add&pid=79
Gigabit VPS 4 ($4.8/month Use coupon ā€œRECURR20ā€ or use coupon ā€œUPGRADEā€ to get upgraded to our next VPS Package)
CPU Core: 2
RAM 2 GB
Bandwidth: 3 TB
Port: Gigabit
OS: Linux/Windows
IPv6: /64
RDNS: Yes
Control Panel: Yes
ORDER Links:
LA: https://my.hosteons.com/cart.php?a=add&pid=80
Gigabit VPS 5 ($5.6/month Use coupon ā€œRECURR20ā€ or use coupon ā€œUPGRADEā€ to get upgraded to our next VPS Package)
CPU Core: 3
RAM 3 GB
Disk Space: 40 GB SSD
Bandwidth: 4 TB
Port: Gigabit
OS: Linux/Windows
IPv6: /64
RDNS: Yes
Control Panel: Yes
ORDER Links:
LA: https://my.hosteons.com/cart.php?a=add&pid=81
Our 100 Mbps Unmetered KVM VPS Packages are as under:
512 MB VPS ($2.4/mo use coupon ā€œRECURR20ā€ or use coupon ā€œUPGRADEā€ to get upgraded to our next VPS Package)
CPU Core: 1
RAM:512 Mb
Disk Space: 5 Gb SSD
OS: Linux / FreeBSD*
IPv6: /64
RDNS: Yes
Control Panel: Yes
ORDER Links:
LA - https://my.hosteons.com/cart.php?a=add&pid=1
NY - https://my.hosteons.com/cart.php?a=add&pid=50
1GB VPS ($3.2/mo use coupon ā€œRECURR20ā€ or use coupon ā€œUPGRADEā€ to get upgraded to our next VPS Package)
CPU Core: 2
RAM: 1GB
Disk Space: 10 Gb SSD
IPv6: /64
RDNS: Yes
Control Panel: Yes
ORDER Links:
LA - https://my.hosteons.com/cart.php?a=add&pid=2
NY - https://my.hosteons.com/cart.php?a=add&pid=51
1.5GB VPS ($4/mo use coupon ā€œRECURR20ā€ or use coupon ā€œUPGRADEā€ to get upgraded to our next VPS Package)
CPU Core: 2
RAM: 1.5Gb
Disk Space: 15 Gb SSD
OS: Linux / Windows / FreeBSD*. (Windows 2019 License available for free with annual billing cycle)
IPv6: /64
RDNS: Yes
Control Panel: Yes
ORDER Links:
NY - https://my.hosteons.com/cart.php?a=add&pid=52
2GB VPS ($5.6/mo use coupon ā€œRECURR20ā€ or use coupon ā€œUPGRADEā€ to get upgraded to our next VPS Package)
CPU Core: 2
RAM: 2Gb
Disk Space: 20 Gb SSD
IPv6: /64
RDNS: Yes
Control Panel: Yes
ORDER Links:
NY - https://my.hosteons.com/cart.php?a=add&pid=53
We have more KVM and OpenvZ VPS Packages they are available at https://hosteons.com/vps.php
**CUSTOM VPS: **(You can Design your own VPS Package, select as much RAM, CPU Core, IP, Disk Space you want)
You can order custom vps from -
LA - https://my.hosteons.com/cart.php?a=add&pid=35
NY - https://my.hosteons.com/cart.php?a=add&pid=48
Private VPN/Proxy allowed, no public Proxies please.Even no spamming or any kind of abusive or illegal activities are allowed on our Network.
Some of our VPS packages offers Linux and some of them offers Linux as well as Windows OS depending upon your VPS Package.
We accept all popular modes of payments like:
  1. Credit Cards (Stripe)
  2. PayPal
  3. AliPay
  4. Union Pay
  5. BitCoin
  6. Web Money
  7. QIWI
  8. Yandex Money
  9. Perfect Money
  10. Bank Transfer
If any queries please submit a ticket from our website https://hosteons.com
Affiliates are also welcome, we offer flat 20% affiliate commission to all our affiliates.
  • Don’t spam ASCII characters (e.g.: ā–ˆ) in the title or body
  • Leave at least a week between offer postings
  • Include your brand/company name in the thread title
  • No block capitals
  • Try to keep the offer condensed (e.g. don’t post 101 services that you provide, just provide highlights and then link back to a products/services page)
  • OPTIONAL Provide a benchmark
Offer Title
Information about the offer…
Add some company information here…
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
