Hostbill or Ubersmith
Howdy,
We are looking for a new platform and in need of support.
Which one would you recommend Hostbill or Ubersmith?
Thanking you. ZI
I am hearing that name for the first time…
Oh really, apparently it is used in the industry by big techs.
Well, they got 2 very good google reviews giving me 2 very good reasons not to go with them!
You are right, I know Quadranet is using the Ubersmith but It is expensive.
Instead of these both, why not to try WHMCS?
If you’re looking for a simple, intuitive, and feature-packed solution, HostBill might be the better choice, especially if you’re managing a lot of hosting accounts and need robust automation and integrations.
Or
If you need something more scalable and are managing larger infrastructure, Ubersmith might be better due to its in-depth business management and hardware management features.
