donko
November 25, 2019, 3:53pm
1
Debian 10. GitHub - myvesta/vesta: myVESTA Control Panel with multiple PHP.
When i run
/usr/local/vesta/php/bin/php -m | grep ioncube
returns nothing
and
sh /usr/local/vesta/ioncube/ioncube.sh
returns
sh: 0: Can’t open /usr/local/vesta/ioncube/ioncube.sh
root@xxx:~# /usr/local/vesta/bin/v-add-vesta-softaculous
dpkg-query: no packages found matching vesta-ioncube
Error: vesta-ioncube package installation failed
I used command to change php cli version
update-alternatives --set php /usr/bin/php7.3
PHP -V
PHP 7.3.11-1+0~20191026.48+debian10~1.gbpf71ca0 (cli) (built: Oct 26 2019 14:20:37) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.3.11, Copyright (c) 1998-2018 Zend Technologies
with the ionCube PHP Loader + ionCube24 v10.3.9, Copyright (c) 2002-2019, by ionCube Ltd.
with Zend OPcache v7.3.11-1+0~20191026.48+debian10~1.gbpf71ca0, Copyright (c) 1999-2018, by Zend Technologies
Can’t find info to fix this most post are only for centos… glad if someone can help me to fix this.
Thanks
What’s the output of?
ls -l /usr/local/vesta/ioncube/ioncube.sh
donko
November 25, 2019, 6:49pm
3
ls: cannot access ‘/usr/local/vesta/ioncube/ioncube.sh’: No such file or directory
WSS
November 25, 2019, 7:14pm
4
These are two of the worst ideas put together that I’ve ever seen.
Insecurities, and one click install software which is generally known to not be secure either.
I will try in next 2 days to find the time to put softaculous in myVestaCP.
opened 02:59PM - 02 Dec 19 UTC
closed 01:37PM - 04 Jan 20 UTC
### Operating System (OS/VERSION):
Debian 10
### VestaCP Version:
I bel… ieve I have the latest version, but not sure if update is working correctly.
### Installed Software (what you got with the installer):
Defaults
### Steps to Reproduce:
Cannot install softaculous through GUI. Cannot install through manual procedure either, complains about ioncube missing. Cannot install ioncube. Got a friend to install softaculous manually, but he couldn't access the installed installation. It just says:
This site can’t be reached 127.0.0.1 refused to connect.
### Related Issues/Forum Threads:
Found anything that might be related to this? It might help us find the cause.
### Other Notes:
Anything else?
Not complete solution, I’m not sure where is the problem.
donko
January 5, 2020, 7:58am
8
thank you so much for this update.
i tried a fresh myvesta installation with debian10 and run your softaculous script but i still get error " * The MySQL Connection could not be established."
curl -O http://c.myvestacp.com/vst-install-debian.sh
bash vst-install-debian.sh --vsftpd yes --proftpd no --iptables yes --fail2ban no
curl -O http://c.myvestacp.com/tools/install-softaculous.sh
bash install-softaculous.sh
i’m running auto installer with a user account (not admin).
i can create databases and manage them from phpmyadmin without problems.
also i’m using custom port and secret url parameter.
I have no idea.
Looks like installer didn’t get fresh version of vesta-php.
I would like to take personally look to your server if you provide me SSH access.
I will try again on my test server.
EDIT:
Hmmm, yes, i got the same error again.
OK, back to drawing table.
No need to send me SSH access, because I reproduced error.
EDIT 2:
Ehm, it’s because secret_url login… ok, it will be easy to solve… give me few hours.
Solved.
Run:
rm /var/cache/apt/archives/vesta_0.9.8-26-3_amd64.deb
apt update && apt install --reinstall vesta
