Hi!
I’m using GitHub - litespeedtech/ols-docker-env: OpenLiteSpeed Docker Environment to set up my dev environment. It should work as it is but Wordpress (litespeed container) can’t connect to the DB. I’m setting the mysql container’s IP manually, but it rotates every time the service is restarted.
So I want to set the DB_HOST variable in wp-config.php to an environment variable name WP_DB_HOST. I’m doing it this way:
version: '3'
services:
mysql:
platform: linux/amd64
image: mariadb:10.5.9
logging:
driver: none
command: --max_allowed_packet=256M
volumes:
- "./data/db:/var/lib/mysql:delegated"
environment:
MYSQL_ROOT_PASSWORD: ${MYSQL_ROOT_PASSWORD}
MYSQL_DATABASE: ${MYSQL_DATABASE}
MYSQL_USER: ${MYSQL_USER}
MYSQL_PASSWORD: ${MYSQL_PASSWORD}
restart: always
ports:
- 3306:3306
networks:
- default
litespeed:
image: litespeedtech/openlitespeed:${OLS_VERSION}-${PHP_VERSION}
logging:
driver: none
env_file:
- .env
volumes:
- ./lsws/conf:/usr/local/lsws/conf
- ./lsws/admin-conf:/usr/local/lsws/admin/conf
- ./bin/container:/usr/local/bin
- ./sites:/var/www/vhosts/
- ./acme:/root/.acme.sh/
- ./logs:/usr/local/lsws/logs/
ports:
- 80:80
- 443:443
- 443:443/udp
- 7080:7080
restart: always
environment:
TZ: ${TimeZone}
WP_DB_HOST: mysql
networks:
- default
phpmyadmin:
image: phpmyadmin/phpmyadmin
logging:
driver: none
ports:
- 8080:80
- 8443:443
environment:
PMA_HOST: mysql
restart: always
networks:
- default
networks:
default:
driver: bridge
But printing getenv( 'WP_DB_HOST')
in PHP returns false.
Any idea?
