DirectAdmin, PHP options
In DirectAdmin, as a user/reseller, not server admin, how to set PHP options?
Don’t see it in the GUI(?), only see the version selector … :thinking:
It’s under Select PHP version assuming your in CloudLinux - I took some screenshots (Sorry on Mobile)
Are you using cloud linux or default php selector?
Uhm :thinking: … That location is exactly where I first checked, and found no options, just a “select version” option, nothing else. Went back there now (two weeks later), and now it looks exactly how I’m used to from cPanel based accounts. Interesting :stuck_out_tongue_closed_eyes::man_shrugging:
Not sure which selector is/was used. I think maybe DA was upgraded since last I checked … (I’m just a customer, not owner …) :blush:
So, anyways, thanks! :smiley:
Thats just CloudLinux, should have been there before. :grin::+1:
Maybe it was browser weirdness, or maybe it was way past bedtime and I mistook the simplified version selector (ref. image below) for the real one … :man_shrugging::vulcan_salute:
I dunno, works like a charm now anyways … :smile:
PHP-selector
