I have a Proxmox server that has been going offline a couple of times since a couple of weeks, when I added a second VM in it. Only the network seems affected until (remote) reboot.
I see these in the logs, maybe it’s related:
Jun 18 20:47:07 dal-node1 kernel: [ 14.029390] device tap210i0 entered promiscuous mode
Jun 18 20:47:07 dal-node1 kernel: [ 14.035468] vmbr0: port 1(tap210i0) entered blocking state
Jun 18 20:47:07 dal-node1 kernel: [ 14.035469] vmbr0: port 1(tap210i0) entered disabled state
Jun 18 20:47:07 dal-node1 kernel: [ 14.035556] vmbr0: port 1(tap210i0) entered blocking state
Jun 18 20:47:07 dal-node1 kernel: [ 14.035557] vmbr0: port 1(tap210i0) entered forwarding state
Jun 18 20:47:11 dal-node1 kernel: [ 17.606185] device tap211i0 entered promiscuous mode
Jun 18 20:47:11 dal-node1 kernel: [ 17.612774] vmbr0: port 2(tap211i0) entered blocking state
Jun 18 20:47:11 dal-node1 kernel: [ 17.612776] vmbr0: port 2(tap211i0) entered disabled state
Jun 18 20:47:11 dal-node1 kernel: [ 17.612856] vmbr0: port 2(tap211i0) entered blocking state
Jun 18 20:47:11 dal-node1 kernel: [ 17.612857] vmbr0: port 2(tap211i0) entered forwarding state
Network config:
iface eno1 inet static
address x.x.x.209/24
gateway x.x.x.1
# dns-* options are implemented by the resolvconf package, if installed
dns-nameservers 8.8.8.8
dns-search theprovider.com
post-up echo 1 > /proc/sys/net/ipv4/ip_forward
post-up echo 1 > /proc/sys/net/ipv4/conf/eno1/proxy_arp
auto vmbr0
iface vmbr0 inet static
address x.x.x.209
netmask 255.255.255.0
bridge-ports none
bridge-stp off
bridge-fd 0
up ip route add x.x.x.210/32 dev vmbr0
up ip route add x.x.x.211/32 dev vmbr0
# more similar lines...
up ip route add x.x.x.216/32 dev vmbr0
I’m using a similar config on another server with no problems at all.
Any ideas?
