Background download does not work with webmin
Hello and maybe good morning,
My freshly installed Debian 12 (HP T630) with webmin, have a small issue with scheduled download.
The small tool in webmin, where you can download from the web, you have two options.
  1. Download right now, and have a peek while it downloads.
  2. Download later, on a specific date/time.
Option 2 does not work for me.
The linux setup is quite basic. Nothing added besides jellyfin. Only stock/default settings. Installed yesterday…latest versions.
Another user in virtualmin discourse forum, replied that option two works just fine in his setup. Australian time/zone.
A cropjob works fine with wget…
When I take a look in webmin.log, I see this when I have started a test-background download.
1728457232.102409.0 [09/Oct/2024 09:00:32] root 35da329bb3cc7bb6a12d12eb2c41980b 192.168.0.xxx updown download.cgi “download” “-” “-” time=‘1728457200’ urls=‘mIRC: Download mIRC
And when I start a direct test-download with the tool, it looks like this:
1728457427.102967.0 [09/Oct/2024 09:03:47] root 35da329bb3cc7bb6a12d12eb2c41980b 192.168.0.xx updown download.cgi “download” “-” “-” time=‘’ urls=‘mIRC: Download mIRC ← This one works.
The time in the background download looks weird “time=‘1728457200’” …
My time should be set correctly, 24 hour format in copenhagen as timezone.
Any tricks?
I’m assuming the post on the Webmin forums is also yours given that it was posted today :smiley:
I’m not too familiar with Webmin, so am unable to offer any real advice (hence why I tried to search instead!). I’d love to hear what the issue ends up being, though :slight_smile:
Oh yes, that is indeed me.
Thanks for writing!
That is one of the main powers of forums… a solution can be shared and found with search engines, that is not the case with discord. So I will write the solution when I hopefully find it…
That time is a unix timestamp. It looks normal to me. Does the file not download?
Hi mwt. No the file never starts. Like the schedule is wrongly set or a misconfig with my timezone, 24h format and … yea.
But I have ignored it for now. It was nice to have as an extra tool if needed.
Check time zone with timedatectl if its okay check is it 24-h format with “locale | grep TIME” if isnt do dpkg-reconfigure locales
