Lighty / Lighttpd Config Options
If running on a small box, try Alpine, PHP and Lighty are both in their repo.
https://wiki.alpinelinux.org/wiki/Lighttpd
As Alpine only uses like 150 Mb of disk space, you can use the spare 1.5 Gb for other things.
Like some extra slow RAM by creating a NVME / SSD swapfile (swappiness = 100) :smiley:
Ah, yes, Alpine seems very nice. Wondered how it’s maintaining/upgrading in the long run?
(Been running Debian and unattended upgrades for a long time. Think I started out with Debian 2.0, or was it 2.1, ran Linux FT, Slackware and RedHat before that.)
Alpine works perfectly, very frequent updates.
And small enough to throw in a Docker container with your lighty/php stack.
That way it’s even easier to control memory usage, the diff in latency is negligible.
As an example :
https://www.cyberciti.biz/faq/how-to-upgrade-alpine-linux-3-4-to-3-5-xx/
# apk update
# apk upgrade --available
# sync
# reboot
:wink:
Is it safe to put in cron something like this(?):
apk update && apk upgrade --available
I assume version (distro release) upgrades shouldn’t skip minor releases? (As in jumping from v3.2 to v3.5 etc.) :thinking:
https://wiki.alpinelinux.org/wiki/APKBUILD_Reference
I would be very careful doing this. The minor revisions seem to come out quite often, and unless you check manually, you could miss a step.
I suppose you could parse Index of /alpine/ and decide what to do, but doing a blind ‘update’ will stop working when your subrevision is no longer current and/or there are no security patches for it.
Just keep in mind that it’s not the same as other distributions that tend to autosync subrevisions - which most of them will do. It doesn’t attempt to. That’s all up to you.
@flips
You got a snappy server now, serving on port 443 ?
Yes, though haven’t tweaked FCGI etc yet. :slight_smile:
Been playing with IPv6 and getting dehydrated to work. (Smoother than certbot + separate Cron job for making the combined cert.)
Will continue to play soon, but first some sleep and work :sleeping: :man_shrugging:
