FAI.me - Fully Automatic Installation
Seems like a pretty cool project:
https://fai-project.org/FAIme/
FAI.me. Build your own installation media or a cloud image
This installation image will automatically install the OS and applications onto the computer. No network connection is needed, since all packages are on the installation media. You can burn this image onto a CD/DVD or write it to an USB stick.
All data on the first disk will be overridden without any further confirmation .
