Hey,
I was trying to access my dashboard at cloudflare it looks like down.
Does it works by your side?
Hey,
Cloudflare Dashboard and Cloudflare API service issues
Investigating - Cloudflare is investigating issues with Cloudflare Dashboard and related APIs.
These issues do not affect the serving of cached files via the Cloudflare CDN or other security features at the Cloudflare Edge.
Customers using the Dashboard / Cloudflare APIs are impacted as requests might fail and/or errors may be displayed.
Apr 15, 15:38 UTC
Awhhh shit… i am waiting for it so i can purge my cache and test my new meta tag. And it looks like it’s killing a lot of things around too…
I was having issues with their dashboard earlier. While everything seemed to be functioning fine, adding DNS records did nothing
Use their api
EDIT: Seems like their API is also having issues
Maybe try adding a query string. URL + ?1
nope not working :c
Seem like the downtime is caused by a maintenance mistake.
The now posted a Blog Post regarding the downtime.
the technician decommissioning our unused hardware also disconnected the cables in this patch panel.
